환경변수 입력 후 에러
2019-12-20 12:25  |  Posted By 김응수
he following FLEXlm errors were found:
    Server 1717@192.168.11.214: Cannot connect to license server system.
 The license server manager (lmgrd) has not been started yet,
 the wrong port@host or license file is being used, or the
 port or hostname in the license file has been changed.
Feature:       pwrshell
Server name:   192.168.11.214
License path:  1717@192.168.11.214;
FLEXnet Licensing error:-15,10.  System Error: 10060 "WinSock: Connection timed out"
For further information, refer to the FLEXnet Licensing documentation,
available at "www.flexerasoftware.com".
    Server C:\flexlm\license.dat: Cannot find license file.
listed below.  Use LM_LICENSE_FILE to use a different license file,
Feature:       pwrshell
Filename:      C:\flexlm\license.dat
License path:  C:\flexlm\license.dat;
FLEXnet Licensing error:-1,359.  System Error: 2 "No such file or directory"
이런식으로 알람이 뜨네요 어떻게 하면 될까요?
window 방화벽으로 발생한 문제였습니다.
인바운드, 아웃바운드에서 1717, 1799 포트를 연결 허용으로 설정하여 해결하였습니다.
