he following FLEXlm errors were found:
Server 1717@192.168.11.214: Cannot connect to license server system.
The license server manager (lmgrd) has not been started yet,
the wrong port@host or license file is being used, or the
port or hostname in the license file has been changed.
Feature: pwrshell
Server name: 192.168.11.214
License path: 1717@192.168.11.214;
FLEXnet Licensing error:-15,10. System Error: 10060 "WinSock: Connection timed out"
For further information, refer to the FLEXnet Licensing documentation,
available at "www.flexerasoftware.com".
Server C:\flexlm\license.dat: Cannot find license file.
listed below. Use LM_LICENSE_FILE to use a different license file,
Feature: pwrshell
Filename: C:\flexlm\license.dat
License path: C:\flexlm\license.dat;
FLEXnet Licensing error:-1,359. System Error: 2 "No such file or directory"
window 방화벽으로 발생한 문제였습니다.
인바운드, 아웃바운드에서 1717, 1799 포트를 연결 허용으로 설정하여 해결하였습니다.
