pads 라이센스 오류
2023-07-05 12:31 | Posted By 장은솔
자세한 확인을 유선으로 연락드리겠습니다.
속성이 PCB 데칼 내에 있는 경우에도 메시지가 발생할 수 있습니다.
Attribute Objects를 Part, Part Type, PCB Decal 및 혹은 PCB로 설정해보시기 바랍니다.
아래는 본사문의 내용의 설명입니다.
Check the attribute that is giving the error to see what objects it has been applied to. For instance, if an attribute is applied to only Part and Part Type, but the attribute resides within the PCB decal then the warning message will appear. In this example, you would need to enable the Decal object type for the specific attribute.
The attribute "Voltage" is a system attribute that is reserved for Nets and Net Class.
If you want to create a voltage for your Components then you can create a New User Attribute such as "Part Voltage". Set the Attribute Objects to Part, Part Type, PCB Decal, and/or PCB
