ECO to PCB 를 했을때 에러입니다.
Line 6 , Section *DEL_ATTRIBUTE*
"Footprint"
* WARNING: Processing command to delete attribute "Footprint" from Component C501.
* The attribute is also inherited from Decal C1005.
* The change is not fully reconciled for cases where the schematic
* does not support hierarchical attributes.
Line 8 , Section *DEL_ATTRIBUTE*
"Footprint"
* WARNING: Processing command to delete attribute "Footprint" from Component C503.
Line 10 , Section *DEL_ATTRIBUTE*
"Footprint"
* WARNING: Processing command to delete attribute "Footprint" from Component C504.
Line 12 , Section *DEL_ATTRIBUTE*
"Footprint"
* WARNING: Processing command to delete attribute "Footprint" from Component C505.
Line 14 , Section *DEL_ATTRIBUTE*
"Footprint"
* WARNING: Processing command to delete attribute "Footprint" from Component C506.
Line 16 , Section *DEL_ATTRIBUTE*
"Footprint"
* WARNING: Processing command to delete attribute "Footprint" from Component C508.
Line 18 , Section *DEL_ATTRIBUTE*
"Footprint"
* WARNING: Processing command to delete attribute "Footprint" from Component C509.
Line 20 , Section *DEL_ATTRIBUTE*
"Footprint"
* WARNING: Processing command to delete attribute "Footprint" from Component C510.
Line 22 , Section *DEL_ATTRIBUTE*
"Footprint"
* WARNING: Processing command to delete attribute "Footprint" from Component C511.
Line 24 , Section *DEL_ATTRIBUTE*
"Footprint"
* WARNING: Processing command to delete attribute "Footprint" from Component C512.
Line 26 , Section *DEL_ATTRIBUTE*
"Footprint"
* WARNING: Processing command to delete attribute "Footprint" from Component C515.
Line 28 , Section *DEL_ATTRIBUTE*
"Footprint"
* WARNING: Processing command to delete attribute "Footprint" from Component C550.
Line 30 , Section *DEL_ATTRIBUTE*
"Footprint"
* WARNING: Processing command to delete attribute "Footprint" from Component C551.
Line 32 , Section *DEL_ATTRIBUTE*
"Footprint"
* WARNING: Processing command to delete attribute "Footprint" from Component C552.
Line 34 , Section *DEL_ATTRIBUTE*
"Footprint"
* WARNING: Processing command to delete attribute "Footprint" from Component C553.
Line 36 , Section *DEL_ATTRIBUTE*
"Footprint"
* WARNING: Processing command to delete attribute "Footprint" from Component C63.
Line 38 , Section *DEL_ATTRIBUTE*
"Footprint"
* WARNING: Processing command to delete attribute "Footprint" from Component C77.
DEL_ATTRIBUTE 메시지는 Footprint라는 속성을 지우겠다는 메시지입니다.
회로도에는 없지만 PCB 상에서 속성값을 지정하시는 경우,
[PADS Layout Link]-[Preferences]에서 Include Attributes를 체크해제하고 사용하시기바랍니다.
