새로운 PC에 설치하고 실행하니 라이센스를 찾을 수 없다는 에러가 나오네요.
몇년전에도 동일한 문제로 원격지원 받았는데 해결방법을 메모를 해둬야겠네요.
도움 요청 드립니다. ^^
The following FlexNet errors were found:
Server 1717@PENTA-01: The desired vendor daemon is down.
Check the lmgrd log file, or try lmreread.
Vendor:Host: PENTA-01
License path: 1717@PENTA-01;
FlexNet Licensing error:-97,121
For further information, refer to the FlexNet Licensing documentation,
available at "www.flexerasoftware.com".
Server C:\flexlm\license.dat: Cannot find license file.
listed below. Use LM_LICENSE_FILE to use a different license file,
Feature: pwrshell
License path: C:\flexlm\license.dat;
FlexNet Licensing error:-1,234
